need help please...
There are 4 screws on the bezle that need to be removed to gain access to the last 4 screws that secure the cluster to the dash. After the 4 cluster screws are removed, just pull it straight out, it's a contact fit in the rear for the connections.
If its anything like a 1g there's a couple trim pieces to remove the 4 screws that hold the cluster in.
Nope, the 4 screws for the bezel are accessible from the start.
Here is a picture:
Blue are the bezel screw locations, and the red is where the cluster screws are located.
Here is a picture:
Di I need to take the dash apart
Well, Its kinda the same idea. (From what I can see) On a 1g, pop a little trim piece off then its 6 screws for the outer trim and 4 for the cluster. Oh yea, and 3 electrical connections. I've been trying to get to know the newer models. Kinda hard without having one tho. Glad to see its just as easy on a 2g.
There are two screws in the bezel at the top. Unscrew them, pop out the bezel, then you can access the 4 screws that hold the cluster in there.
I took the 2 top screws out but the bezel wont come out it feels like more screws are holdin it in but there's no other screws..... nevermind I had to pry it off. Thanks fr the help everybody
Does anybody know if the separate little dash bulbs can bought in different colors?
no just drop the steering wheel down to its lowest setting this is possibly the most simple task in taking a piece of the interior out
