2G Need help identifying plugs
cficare68
87
Aug 29, 2010
Boise, Idaho
In the process of putting together a 95 Talon tsi. I installed an engine wiring harness from what i believe came from a 98 auto and there are two plugs on the inside of the car that i can't for the life of me seem to locate their mates. Can anyone give me some information on what these plugs are for and where they go. Thanks!
Picture 1 looks like clutch switch
Picture 2 goes behind your kick panel fuse box above and to the left of your pedals (can’t remember what it’s for though) I know it’s a pain to get to. I believe it plugs into a connector with foam insulation on it
Clutch switch isn't located on the main the engine harness. I know that it isn't for that. I am converting a manual car to an auto and I had to unplug the clutch switch when I pulled the clutch pedal out of the car. On this branch of wires there are 3 plugs. The two that I've mention and then a third that clips in at the base of the shifter for the auto trans.
