Need help identifying my DSM
Se7en x Eclipse
Jan 9, 2012
Utica, New York
So I recently bought a 97 eclipse, only problem is i dont really know which trim is it (It's deff not GSX/GST) On the papers that the dealer gave me said it was a GS, but I didnt believe it, it has roll up windows, manual locks,cloth interior, has a high rise spoiler. People tell me its a RS, But i thinks its a base model, not too sure though, any thoughts?
When you insure it you give the vin number, this will tell you what trim level it is. This happened with a Del Slow SI that I was trying to pass off as a base model for cheaper insurance. I was a thinker when I was young......:ohdamn:
I would definately think it's an RS, seeing it does not have any power option. Just call your local Mitsubishi dealer and give them your VIN, they can tell you for sure.
As he said, go by the vin, quick and precise.
Decoding VINs
VIN # TELLS IT ALL GO TO CARFAX, I GOT A WEIRD THING ON MY 95 tsi SO THE VIN SAYS MY CAR IS AN AWD BUT AS FAR AS I KNOW ITS A FWD, GO FIGURE.
Only the rs came with rear drum breaks. If you dont have them its a gs.
Correct me if I'm wrong, but I beleive all DSM's other than AWD's have drums on the rear from the factory.
As far as rear drum brakes are concerned some RS and ESi came from the factory with them.
No GS or GST-T or GSX, I've ever seen had drums in the rear.
And all models could be purchased with out a sunroof.
To the OP run your vin number it will tell you the model.
Usually the roll up windows are a dead giveaway to a RS model.
