Need help finding a new starter that fits my car
GeeZuzz
69
Dec 23, 2005
Norway, Europe
I think the starter in my car is broke. Nothing happens when turning the switch (no sounds), except the fuse "explodes".
I don't know much about cars, but someone with a little better knowledge than me says it must be the starter, since he tested cables etc.
But the big problem is to find a new starter that fits my car - a 1998 Eclipse GS w/automatic trans.
Does anyone know exactly what model/serial the part has? The sticker on it is unreadable. :(
Before you go getting another started, make sure you check your ground. The same thing happened to my car and when i'd turn the key, it would just click and the fuse would pop. Turned out the ground that plugs into the starter itself was all corroded. But, if it turns out that it IS the starter, just call your local salvage yard and they'll get you one, you'd be suprised how many different cars use the same starter/bolt pattern/everything. :thumb: :talon:
Thanks for your reply. I bought the car in the USA, where it was working fine. Then the car was picked up and shipped over to Europe, and when it arrived to where i live, it was no longer starting. The car had a "custom" power switch - a button that needed to be switch to ON while turning the key, and then to off again afterwords. We suspect that the shipping people did not understand this, and left the switch in ON position, which probably broke the starter. The battert was also flat (we have off course tried external power)
Anyway, they don't sell the eclipse in my country, so it's not the easiest car to get parts for... We got a new starter for eclipse, but it did not fit. And they have troubles finding a new one. If we knew the exact part number it would help... Or if we knew any other cars using the same starter?
I ran a cross check on applications on the starter your car has. If you can find the starter for any of these cars you are in business. good luck.
Dodge Colt 1991 - 1994 91-92 (1.5ltr) w/ Auto Trans.
Dodge Colt Vista 1992 - 1994 (2.4ltr) w/ Auto Trans.
Eagle Summit 1989 - 1991 1991 (1.5ltr) w/ Auto Trans.
Eagle Summit 1992 - 1996 1992 (1.5ltr) w/ Auto Trans.
Eagle Summit Wagon 1992 - 1996 (2.4ltr) w/ Auto Trans.
Eagle Talon 1990 - 1994 91-94 (2.0ltr)
Eagle Talon Turbo 1990 - 1994 91-94 (2.0ltr) Mitsubishi System
Eagle Talon Turbo 1995 - 1998 Mitsubishi System w/ Auto Trans.
Hyundai Elantra 1992 - 1995 w/ Auto Trans.
Hyundai Sonata (4 Cyl.) 1992 - 1996 (2.0ltr) w/ Auto Trans.
Hyundai Sonata (4 Cyl.) 1997 - 2001 1997 (2.0ltr) w/ Auto Trans.
Mitsubishi Eclipse 1989 - 1996 5/90-94 (2.0ltr) w/Auto Trans. 1996 (2.4ltr) w/Auto Trans.
Mitsubishi Eclipse 1997 - 1998 1997 w/ Auto Trans.
Mitsubishi Eclipse Turbo 1990 - 1996 2WD 5/90-96 w/Auto Trans. or 4WD 95-96 w/Auto Trans.
Mitsubishi Eclipse Turbo 1997 - 1999 1997 w/ Auto Trans.
Mitsubishi Expo (5 Door) 1992 - 1996 w/ Auto Trans. Mitsubishi Expo
LRV (3 Door) 1992 - 1996 92-96 (2.4ltr) w/ Auto Trans.
Mitsubishi Galant 1989 - 1993 2WD 12/89-93 (Sohc) 1990 (Dohc) w/ Auto Trans.
Mitsubishi Galant 1994 - 1998 w/ Auto Trans.
Mitsubishi Mirage 1989 - 1992 91-92 (1.6ltr) w/ Auto Trans.
Plymouth Laser Turbo 1989 - 1991
Plymouth Laser Turbo 1992 - 1994
^what he said :p
Thanks a lot! I'll bring that list to the local dealer.
