need help fast
slick06emp
53
Apr 28, 2009
Lawrenceville, Pennsylvania
ok so i got an safcII and started to tune but when i try to hold my rpms steady at 1000 2000 and up to 4k they bounce...kind of like a rev limiter. i know its not that but what could it be? IAC? my egr is blocked off..no vacum leaks. after 4k i can hold them steady but under that they build to the desired number but then fall down to 800 and bounce back up....any ideas?
You could unplug the IAC. Set the lower RPM ranges, then plug it back in. It does seem strange though. I could see it doing that at 1000-1500, but I wouldn't expect that at above 2000. Although once the safc is set up right it might not.
