Spoolin98
- 1,646
- 23
- Feb 1, 2004
Easton,
Pennsylvania
91-gsx said:i read through all 3 links and have a few more questions, you must have never guessed.... anyway, i bought a set of arp headstuds that have not been used but do nto come with the special arp lube. what type of lube should i use on the bolts and nuts? and what do you all recommend i torque them down to sense i have heard way too many different numbers? the last question is if i have my head machined flat because of warpage, do you think the block would be warped as well?
thanks again
ARP suggests a good quality Moly Lubricant if you do not use their lubricant, torque to 80ft/lbs. If you dont use a moly lube, use 30wt oil on threads and washers and torque to 120ft/lbs. Most likely your block is not warped, iron is a lot harder to warp than aluminum. The only way to be sure is to get a straight edge ruler and feeler gauge and check it yourself. Or pull the block and take it to a machine shop and have them check it.
http://www.dsmtuners.com/forums/search.php?searchid=1804672
