NEED help Buschur FMIC install 1g
saxrulez
83
Feb 4, 2004
Fayetteville, North Carolina
I've run into a serious problem with my fmic install....
The BOV is directly in the way for the MAS, no amount of wiggling or pushing/pulling will let it fit where it is. I've got to have something incorrect, but I just dont know what...
Well, that being a 45* bend, u try turning it around so bov is up near valve cover? should still clear the hood. Otherwise, u could probly switch itwith the lower 45* bend that meets the intercooler, but bov will be way down there.
or rotate the intake pipe away from the motor a little, should push mas towards front. to me, with 1min of wiggling it looks like it should fit fine.
Well, I'm retarded, I knew I was making this harder than it was supposed to be.
Turned the pipe around. I'd tried that earlier, but the pipe was being pushed up from the way i had the cruise control mounted then, so it was hitting the hood with the BOV that way. Just had to run the CC lines over the UICP and flip the pipe around. OMG
