need help big time! not starting
mitsuclipes
Nov 10, 2010
Collinsville, Illinois
well to begin i have a 97 GST with a 1g head did a full rebuild on the motor all new gaskets car did run before i pulled the motor didn't run the greatest well this is what i got my car will not start what ive replace i have a new coil pack wires plugs 1G CAS got from the junkyard car had 83000 miles i tested the power going to the pig tail have what the factory power should be at i do have fire on 1 and 4 but not 2 or 3 didn't some research on this forever i notice that 2/3 have its own pin out on the ecu ive been trying to figure this out now for a month car turns over it sounds like it does want to turn over i can hear the compression i do get fuel to all cylinders. the last thing i haven't replace is the ecm could this possible be it ive replace everything that can cause this problem even new ignition module on the side of the head im mean im just stuck on this dam car i would love to drive this car one day haha. the ecm does have some type of yellowing on the back side of the ecm and looks like there a nasty crack on module things on the ecm aha don't know what there called but if anyone can help me and point me in the right direction i would appreciate it. thanks
i did last time i check and its said the crank cam was bad replaced it and havnt check it yet gonna do that tomorrow more than likely couldnt get oreillys to let me borrow the obd2 scanner dam newbies at that store wish the ppl that i talk to were there working aha
I can barely follow your thread you need to use proper punctuation. Sounds like you have parts all mixed up, I would say its an electrical wire issue. You need to unplug the cas and see if it turns over or if that gives you power to 2 and 3.
