need help a.s.a.p!
Vice-Grips are your only hope. You will have to latch those puppies on tight and hope to god you can hold them still while you bust the line loose with a wrench.
Gator Grip, any hardware store should have a tool like so...
Its not that bad I ve seen worse!
looks like the lines crimped but i dont see why vise grips wouldant work probably ## best bet
sence its on car and fuel might be in line my idea pry wouldnt work. but i have before taken a pice of junk metal and welded like a small pipe onto it then pushed on that to break it loose then you can usually vice grip it off.
Irwin vise grips. They never slip. Im am a mechanic by trade and I use these often. They will shave metal off first. They are a last option. If they fail you are going to have to replace.
