need help 2g talon
tehvirus
Mar 31, 2011
annandale, Minnesota
i have a 96 talon 420a. Recently it started to develop a problem that i cant figure out. It will run fine for 10 mins then the check engine light will flash and the rpm gauge will go crazy and it will misfire and die. If i try to restart the car it will idle at 100 rpm, for a couple seconds then die and wont crank over again. anyone have any ideas of what could be causing this?
I also say check the coil. They run the same style coil you see on the DOHC neons, and those were notorious for going bad.
thanks for the replys. I replaced the coil pack to no avail then i checked the fuel pump and it was not bad, now i replaced the cam shaft sensor and the same thing is still happening does anyone have any other ideas??????
If the CEL is on, why don't you scan the PCM for codes? Report back with whatever code you find...
it only turns on about 2 mins before its about to die
VelocitàPaola;152763731 said:
That's long enough to pull the code... Seriously, though, the PCM may store a code without illuminating the CEL.
i understand what you are saying and i tried the key trick but got nothing and i wont have a code reader untill saturday
Could be the ecu or check and see if your crankshaft position sensor went to crap. Its located above the oil filter housing
  • Wanted 4G63 800cc injectors
    Im looking for a set of injectors that are at least 800cc. Thanks!
    • DSM_Thorpe
  • For sale 2g 2g rear brace arms
    2g rear subframe brace arms. Missing one of the bushing spacers. No rust. Had someone looking...
  • For sale 1g 1GB Eclipse Tail Lights
    1GB Eclipse Tail Lights $80 + shipping and paypal fees* not flawless but in very good shape...
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
