Need Confirmation of Fitting Size Clutch Slave to hard-line
dot45
Supporting VIP
140
Sep 26, 2011
Michigan
In the process of adding some goodie's to the car, and want to remove the accumulator from the clutch hose. I am trying to determine the fitting for the end of the slave hose, that connects to the hardline. I am trying to get the hose this weekend, so I need the specs to have the local hydraulic shop make me one.
This thread is the only one I could find while searching:
http://www.dsmtuners.com/forums/newbie-forum/409449-clutch-damper-slave-ss-lines.html
It states:
The slave cylinder fitting should be a M10x1.00 thread and the master cylinder should be a M10x1.25. The ID of the line should be 3/16" ID in which 6 ft of -4AN teflon lined SS line will suffice. (although -3AN is about 3/16")
I use a 180* on the slave cylinder and a 90* on the master cylinder. Both steel fittings.
