Need Advise
snowboard1
70
Aug 9, 2004
West Newton, Pennsylvania
Hi, I am about to buy an fp 18g to put into my 14b turbine housing
I was wondering if I can run this fp 18g on my 6cm housing at 9 psi with stock side mount intercooler and stock injectors.
Will I get heat soak? Will I max out my stock injectors?
I am planning on getting a front mount intercooler and 650 cc injectors to turn up my boost and get my maft dyno tuned by slowboy
i don't think you should be heat soaking for the fact that i heard the stock smic starts to heat soak at 18 or 19psi. so at 9 psi heat soak should not occur. the only chance i see it heatsoaking is if you try to do constant runs one after another.
maxing out your injectos hmm??? grab your logger and tuning device and see what your duty cycle is.
with a good fmic and 660's you shouldn't worry about heatsoaking or maxing out your injectors anytime soon..... have fun at slowboy :thumb: i plan to head down there sometime in the winter to get dyno'd.
