Need a restricotr?? HY35
Bubbas Garage
30
Mar 25, 2012
Watertown, South Dakota
I am in the proccess of putting an hy35 on my 1g talon. I have the -4an Feed line (off the Oil Fitler Housing) , and -10an return line, both from Extremepsi.com. Will i have any problems with this setup? And Should i run a restrictor? If so what restrictor should i run? ( links would be great )
Thanks
Jordan
When i get everything istalled and fired for the first time i will get a reading and ill get back to you! Thanks :)
...so bad that you could never run a 9.20 with a restrictor on the same turbo on the car for the past three years. :rolleyes:
Your turbo wants no more than 75psi at the inlet. Restrict only enough to get the peak pressure to 75psi, and it will last forever. If you make 90psi peak, only a slight amount of restriction is necessary to achieve 75psi.
