Need a little guidance
91gsx123
42
Jul 25, 2010
louisville, Kentucky
Simple question, just getting my motor back together and im not sure which coolant line goes were. There are two ports off the bottom of the throttle body and im not sure what port the lines go to by the thermostat housing.
the motor is running a 90 style oil cooler.
It looks like you're running a sheet metal manifold, so your throttle body sits a lot lower. It won't matter which line goes to what on the throttle body. Basically connect the ports on the left of the picture to the ones on the right on the picture. It may be a pain in the ass for you getting the air out of the FIAV now because it sits so much lower.
Looking from the front of the car:
The Left port on the TB goes to the Water Neck port.
The Right port on the TB goes to the Water Pipe port (tube that runs back to the heater hose and forward to the Water pipe)
Like this:
<img src="http://a.imageshack.us/img203/7683/dsmwaterpipes.png" alt="Image Hosted by ImageShack.us"/>
Hope this helps :)
