ECMlink Need a little advise
mchustle
800
Aug 8, 2009
johnson city, Tennessee
Hello all I just started working on my SD tune after I threw my new injectors in. I installed the 680cc AMS(delphi) injectors I traded my evos for, and started completely from scratch. I did a small cruise and started using the tool to adjust my sd table. I know my table is a mess right now I just wanted to get some advice on my deadtime because it seemed a little high to me. I think I may have a small boost leak or 2, but assume that shouldn't matter because of SD. Any input is appreciated. Thanks
A boost leak isn't going to affect you the same way as if you are using a MAF but you are still going to have an improper tune with leaks which can still affect other sensors.
No boost leaks, no exhaust leaks, verify sensors are working properly.
