420A Need 1996 ECU Pinout
Smash_NDash
52
Jun 11, 2011
charlotte, North Carolina
Im working on a custom install of my megasquirt using a ecu connector (because I want to run full stand alone but I have to switch back for emissions every year) and I cannot for the life of me find a 1996 ECU pinout.
If anyone has one or knows where I can get one please let me know!
2GNT.com - ECU_Pinout
If you have a early model 1996 with single plug ECM, the pin out is about identical to the 1995 ECU. If you have a later model 1996 with the two plug, the pin out is almost the same as the 1997 ECU. Good luck
I saw your post from that in an earlier thread but I need to know whats different/changed if I am going to refer to the 97 diagram without having to go to my car to look.
Since I am building a PnP harness I need to know exactly where each pin is
There weren't any changes to my knowledge. If you find any, report back with them please, but I don't think you will.
2GNT.com - 1997_ECU 2GNT.com - 1998_ECU by looking at the first 10-15 pins it looks like a noticeable difference... looks like 10 or so pins are different between these two diagrams.
SO I would assume that I should use the 97 pinout because its teh closest to the 96 as far as production goes
thank you! you just solved about 2 weeks of searching and e-mailing folks.
But i do have a follow up question if they are all the same why did howell/AFX offer year specific computers?
