Nails on chalkboard sound from clutch!
1997eagletalon
Sep 16, 2008
norwalk, Ohio
ok when i press the cluth in it soulds like nails on a chalk bored.. also i can not put it in gear when the car is running. only when it is off once i have to started and hit the clutch to put it in first it sounds like nails on a chalk bored its wired i need some help so if anyone could give me any ideas let me know thanks
If no more fluid can goes into the transmission ( by the filling plug ) this is cause it's full of fluid. The fluid level can not be higher than the filling hole.
Your description of the trouble that you have sounds to me like a bad throw out bearing. But it can be other things. IT's hard to say ... post a video
Are ALL of your Engine to Trans bolts tight? If one is loose, I've seen starter plates hit the flywheel, sounds like chalkboard fingernails... I thought it was a throw out bearing, or a bad trans, but it was just a starter plate.
Good luck!
Had a similar problem. Was the throw out bearing. I would say that. But as for it not going into gear unless you shut if off first, sounds like a bad clutch. How many miles you got?
