NA Camshaft Upgrade Benefits
1g8420a
106
Nov 19, 2011
Fort Riley, Kansas
I am looking into a set of NA grind camshafts. I have a semi built bottom end and a stock rebuilt head. I saw that alot of guys run the crower stage 2. I was wondering if anyone has run the Brian Crower Stage 2's? Also when running stage 2 or 3 cams is it beneficial to have cam gears installed or can you run stock gears? (I am going to replace the valve springs and retainers) :thumb:
Cams aren't going to do much without a way to tune. What are you trying to do, go turbo or stay na?
Also, next time, please use a more descriptive title ;)
I was going to use a more descriptive title but, the moderator seems to change my title all the time so.. next time I will put, "chuck norris uses crower 2's on his 420A" :sneaky: anyway I am looking into megasquirt right now I will be tuning the car and also for the next year or so I am gonna stay NA. when I am ready to boost the car I will change the cams.
Just looking to add some attitude to my DD
Those cams are pretty popular with the n/t crowd. You can get some extra pep out of the car with them dialed in properly. I'm also pretty sure you can use the same cams when you go turbo, I haven't heard of anyone having issues running them like that.
