N/T ABS Delete
bigbird94
264
7
Jun 22, 2011
Fond du Lac, Wisconsin
I have done in a lot of research on ABS deletes and what is needed etc and still have not found just what I was looking for....
There is a NT eclipse at my local junkyard without ABS. The prop valve, lines from master cylinder to the valve and the lines from the valve to the brakes are all there and in good shape. I am not sure what year it is but it is a 1gb (92-94).
I was wondering if I could pull the non abs stuff off the NT car and swap it into my 92 TSI AWD. Will the NT brake lines and prop valve be the same parts a turbo car would have? Im also wondering if I can reuse my brake lines to the rear brakes with the NT prop valve.
Any help would be great, Thanks!
