N/A head on turbo car
sLo-DsM
Feb 1, 2006
The Burg, West Virginia
will the head off of a 4g63 work on a 4g63t what would have to be done and what are the diffrances?
The 4g63T and the 4g63 use the same head. The only difference is the cams. You will need the cams from a 4g63t to make it work. :thumb:
So the place for the oil line for the turbo is there in the N/A. reason is i bought a 4g63t for a swap into a colt and the manifold bolts are all broke off and has a burnt valve and cracked manifold. are the lifters valves ect the same
Yes, the only difference is the cams. If this is indeed a head from a 4g63 N/A.
yea its a head off a 4g63 n/a thanks alot man what about the intake manifold they the same??
i got the 4g63 for $300 from a salvage yard i heard it run just needs top end work has i think it was 70,000 miles around there and a guy said he had a full head from a non turbo car has everything on it manifolds and all for $40
