my vr4 wont go into gear.
16g-2ndgen
243
Nov 2, 2007
FLW, Missouri
ok, so i buy the car 3 months ago.. shifts fine.. then coming up to about 2 weeks ago it becomes harder.. and harder to go into gear. i thought it was the transmission but everything is fine, and when im at a stop and its in first gear or reverse with the clutch pedal all the way down and if i rev it the car will start to move like the clutch is still engaged. would this be a cause of my cluttch pedal needing adjustment?( that little metal bolt thing behind the pedal). if soo how would i come around to adjusting that, and which way would i turn it to make it possibly make the clutch engage earlier.
Check Bushings on the tranny cables while your at it. The one at the tranny and the ones under the gear shifter.
ok, my computer does not want me of vfaq this week for some reason.. and all the bushings are all new along with the shift linkage, slave and master cylinders and clutch. ill check anyways.
