my trans not going into overdrive
boosted_4life
May 21, 2009
Gulf Breeze, Florida
Ok here is the issue, when I start driving the car shifts fine, but when it gets time to go into overdrive it feels like is going i neutral, but if i turn overdrive off it goes back into gear.WTF what can my problem be? By the way this is on a 1995 gsx automatic.
Possibly your end clutch has failed?
End Clutch Install
Doesn't sound like a switch problem if you say you are turning it off and it engages back in 3rd.
Could also be catastrophic damage that a fluid/filter change and end clutch kit won't fix.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
