My scan tool and my DVOM disagree.
My scanner says that my battery and alternator are bad but my meter readings look good.
CES
Available voltage @ the battery with the engine off. Negative to negative positive to positive.
At the battery with the engine running and loads off.
Available voltage at the alternator -red lead to the alternator output post and black lead to battery negative with engine running and loads off.
Voltage drop test of the alternator output cable.red to alternator stud, black to battery +.
The voltage drop was .55 so cable was upgraded to a 4 gauge cable. From two 8 gauge cables that are wired in parallel from the factory.
Voltage drop of the ground side next. Measure negative circuit voltage drop by placing the black lead of the voltmeter on the housing of the alternator and the red lead of the voltmeter on the negative battery terminal. If the reading is less than 0.03 volts, verify the alternator is charging and retest.
  • Wanted Wanted 1g 1G Leather Shift Knob
    OEM leather shifter for 1992 Eagle Talon TSI
    • Knight_rider
  • Wanted 2g manual rear diff
    Need a 2g open or lsd rear differential for manual transmission
    • Schinjon
  • For sale 2g 1996 GS-T Eclipse Rolling Chassis + Extras
    1996 GS-T Eclipse Rolling Chassis, Includes Interior & Electrical bits - No Engine or Transmission
    • KYBill
  • Wanted Wtb built tcase
    Looking for a built 300m automatic tcase years 91-96
    • El_marto
  • For sale 1G DSM 4G63 PARTS LOT
    Cleaning out my shop closet, Buyer covers shipping & fee.Parts:1GB Tail-lights - $100Power...
    • The_Partout_Spot
