MY new 98 Gst
boost4you
Jul 5, 2006
kalmazoo, Michigan
My New summer toy Austin From Sim racing
My project GST...Check it out on StrictlyImportMotorsports.com
Goals 450HP/12 sec dd
The plan
HEAD:
7 Bolt head
porting Polishing my head
Super tech stage #1 springs
SIM RACING Viton valve seals
SIM RACING Racing Valves
SIM RACING 275 Racing CAMS
Comedic 4 layer head gasket
ARP head studs
ENGINE:
Wire tucked very nicely
keeping 7 bolt block
Eagle Weisco
New Gates timing belt
Maby A 2.3 Anyone....:aha:
Drivetrain:
stock Transmission
ACT Street Light weight flywheel
ARP Flywheel/Clutch bolts
Exedy 6 puck center sprung
Exedy EQUAL slave cylinder
TURBO/FUEL:
Holset hx30
custom Racing Manifold
custom oil feed and return line kit
Fuel lab fuel presser regulator
fic 900cc Injectors
Walbro 255 Fuel pump
Twin Tial 38mm Wastgate
HKS SSQV blow off
full 3" down pipe And exhaust
FMIC 3" inch ICP
Engine Management:
DSM LINK V3
Halman Boost controller
AEM UGO Wide Band
Suspension/brakes:
Eibach sportline springs
Energy suspention mounts
Drilled and slotted rotors
Hawk pads
MISC:
Rims gram light knock off bronze 17"
COP Setup
Tuned to 97 or race gas for daily use race gas at the dragstrip
All cometic Gaskets
Battery Relocated to trunk
Gates racing timing belt
Gates Racing ALT Belt
Gates racing Radiator hoses
Honda 1/2 Alum Radiator
SIM RACING EGT block off
SIM RACING coil on plug kit
lucky guy, i wish i worked at shop so when i blow my motor i can say "no biggie" and just grab one off the wall like nothing happened. LOL
where is your Fuse box at?? just curious
and did you spray that block a gun metal color, or is it black i cant tell?
anyways good thread keep the pictures coming..
man looking good austin. cant wait to have all of us rolling around in 2g's this year :)
Hey man thanks for the support and block is gunmetal and the fuse box is in the fender well up by the bumper all the wires are attached to the bottom of the frame rail.
I want your car man....That much power in a GST would be such a fun car to drive...Go down the highway at 50 by some civic and just roast of the tires haha
ya i like the color choice for the block alot.
do you mind taking a couple quick shots of the fuse box location for me?? trying to get some more ideas as where to mount mine??? Thanks in advance man
Drew
im protecting my thread and new company SIM RACING...ok pple thats what this is about
Let me just start by saying i used to work at dsm graveyard also and i also quit because i thought that what they where doing was flat out wrong.
Jon walker is personaly a great guy but in the business world their is things you do and just cant do to stay in business.
When you call to ask about your very expensive engine build you should be able to get a strait answer instead you get the run around and everone that has ordered knows this. Jon has told me to tell people stuff will be done and shipped when their is no chance that it will. thats my biggest issue if you cant handle the work dont take money!!!!
I think Jon you need to stay off allens thread this is not a way to settle our person vendettas if you have a problem with us using some of your ideas get over it. Thats just business and thats how it works and come on about giving good deals you charge your best friends mark up so you can make a profit for your time you not the buissy or holy Jon.If you have an issue ill see you and the graveyard in court....stay off our personal threads i think the mods will agree this is not the place for you to wage your personal war.....:notgood:
  • Wanted 6 bolt NT water pipe
    • chrisman287
