MY new 98 Gst
boost4you
Jul 5, 2006
kalmazoo, Michigan
My New summer toy Austin From Sim racing
My project GST...Check it out on StrictlyImportMotorsports.com
Goals 450HP/12 sec dd
The plan
HEAD:
7 Bolt head
porting Polishing my head
Super tech stage #1 springs
SIM RACING Viton valve seals
SIM RACING Racing Valves
SIM RACING 275 Racing CAMS
Comedic 4 layer head gasket
ARP head studs
ENGINE:
Wire tucked very nicely
keeping 7 bolt block
Eagle Weisco
New Gates timing belt
Maby A 2.3 Anyone....:aha:
Drivetrain:
stock Transmission
ACT Street Light weight flywheel
ARP Flywheel/Clutch bolts
Exedy 6 puck center sprung
Exedy EQUAL slave cylinder
TURBO/FUEL:
Holset hx30
custom Racing Manifold
custom oil feed and return line kit
Fuel lab fuel presser regulator
fic 900cc Injectors
Walbro 255 Fuel pump
Twin Tial 38mm Wastgate
HKS SSQV blow off
full 3" down pipe And exhaust
FMIC 3" inch ICP
Engine Management:
DSM LINK V3
Halman Boost controller
AEM UGO Wide Band
Suspension/brakes:
Eibach sportline springs
Energy suspention mounts
Drilled and slotted rotors
Hawk pads
MISC:
Rims gram light knock off bronze 17"
COP Setup
Tuned to 97 or race gas for daily use race gas at the dragstrip
All cometic Gaskets
Battery Relocated to trunk
Gates racing timing belt
Gates Racing ALT Belt
Gates racing Radiator hoses
Honda 1/2 Alum Radiator
SIM RACING EGT block off
SIM RACING coil on plug kit
450 hp is def going to put you in the 11s unless you cant drive your car. but with those hp #s my mom could put your car in the 11s. good luck man:hellyeah:
Says the guy with awd :tease:
On street tires, much easier said then done but with a proper set of slicks, 11's shouldn't be an issue with 450whp. Back when my car was fwd I ran a best of 12.2 @119 but with a 2.0 60 (drag radials not slicks). There was still more in the car to be had but I swapped to awd before I had a chance to go further. That was with basically the dyno #'s posted on my profile, except I ran 1-2 psi more at the track vs that street dyno tune.
Well last night we got a little boost happy and the car spiked 28 psi spun a bearing and has a very suddle rod knock we trailed it home and are pulling the motor this weekend.
looks like i might have to go cheap for a bit and just throw in a crank kit and do a re ring. But just to get it on the road not expending to get power out of it just need to get it back on the road for like a month or so, Im building my race motor on the side.
new parts list form DSM Graveyard
Crankshaft Kit - 7 Bolt
List Price: $539.99
Sale Price: $290.00
New Hastings Piston Ring Set - 95-99 Turbo
Our Price: $99.99
Sale Price: $79.99
I'm sorry, but I HAVE to ask this. What the hell kinda radiator is that and is it efficient? Why aren't we seeing more people use a rad like that if it works to save space in the bay?
By the way, AWESOME car, sad to hear about your boost spike issue. But GLAD to hear you're not afraid to use the 7bolt motor
honda half, I have ran them in two of mt cars never had an issue this one runs(ran) cold actaly
ok but WHICH honda half!? Del sol? civic? are they the same? Thank you guys for telling me this! I gotta try that out on my awd project...
Every time I have seen them they are labled as a civic half radiator. I believe that they are somewhat universal though. And yes you can get them very cheap. I have been very interested in trying it as well.
Delete that power steering, gahhh.
Your bay is so uncluttered and nice, that ugly PS canister kills it.
Also, a 12 second fwd car could use a strut tower bar too, gonna have alot of torque steer.
And, get a catch can for that valve breather, and PCV too if you want.
got the new block prepped last night hope to be dropping it in tomorrow...
Me and the guys at the Graveyard put this together to get my car back on the road thanks guys for all your help.heres pics of the tear down,re paint and wire tuck.
Before tear down
After turbo was off it took forever gotta love this setup...LOL
Big turbo hx30
Before paint and wire tuck power steering was removed just for you (EclipticalGS) looks crazy clean now...
After paint
Shavings in Oil pan nothing a little jb weld cant fix LOL...spun a main bearing got a new block prepped and ready to stick in god i love working here, i just grabbed one off the shelf.
Calling it a night
