My new 92 gsx 5speed
DanThMan1983
245
Dec 24, 2005
Omaha, Nebraska
Even though I have been a mustang freak my whole life I have always admired DSMs and I have been looking for a second car because I put the mustang in storage and I do not like driving my brothers car. I did alot of looking around for a few months driving some pretty rough :dsm: . I finally came across this one and bought it. Let me know what you guys think :) I love it. ($3300 just under 190k miles)
EDIT>> Also I really really like the extensive work you guys have put into the tech articles on tuning. Great site!
1992 Eclipse GSX AWD 5Speed
Pictures:
Modifications:
New from the head up(3500 miles)(head, gaskets, waterpump, ect.)
Newer Transmission and Clutch
2g Pistons
RC 550cc Injectors
255lph Fuel Pump
Fuel Pump Rewire Kit(not installed)
2g MAF with Dejon Intake
K&N filter
2g Exhause manifold
Stock 1g BOV
Big 16G ported and clipped
SAFC-II
Manual Boost Controller
Data Logger on PalmPilot
2.5" exhause no cat dynomax muffler
Upgraded ECU and EPROM
Autometer Boost and A/F Gauges mounted on A-Pillar
Greddy EGT Mounted in Dash
Clarion DXZ-935 CD player
20% tint all the way around
Drilled and Slotted rotors
Lazer wheels
and... my mustang...
1987 Mustang GT 5 speed Hatchback
Pictures:
Modifications:
Flowmaster Exhaust
Centerforce dual friction clutch kit w/ Centerforce throwout bearing and pilot bearing
Energy Suspension Poly. Motor Mounts
Pro 5.0 shifter
HPMotorsports Sub Frame Connectors
OEM style Fog lamps
BBK X-Pipe
BBK Full Length Headers
Ford Racing e303 cam
Ford Racing Oil Pump
Engine Overhaul Gasket Set
Aluminum pedal covers
Plugs and Ford Racing Wires
Competition Cams High Energy Pushrods
Crane Valve Spring and Retainer Kits
Crane Machined Steel Valve Locks
Ford Racing Double Roller Timing Chain Set
Ford Racing Hydraulic Roller Lifters
Ford Racing Roller Rocker Arms (1.6 ratio)
Flexlite Electric fan
Speed-Pro Forged Aluminum Pistons
Speed-Pro Piston Rings
Clevite Main and Rod Bearings
Eagle Connecting Rods
Autometer 5" Tach wtih Shift Light (Stolen)
Autometer Mustang gauge pod
FordMotorsport Tall Chrome Valve Covers
ASC Industries Water Pump
Roller Rocker Pedestal Guide Plates
Oil Pressure Sending Unit
New Thermostat
Smog Pump Eliminator Plugs
TrickFlow Intake Manifold
Ford Motorsports Mass Air Conversion Kit Includes:
Cobra Mass Air Computer
Mass Air Meter
24lbs Injectors
70mm TrickFlow EGR spacer
2" A/F Gauge
2" Oil Psi Gauge
Power Steering Pump
Aerospace Components Pro Street Front and Rear Disc Brake Kit Drilled Slotted and Zinc Coated
Aerospace Components Proportioning Valve
Aerospace Components Master Cylinder Upgrade
Strange Engineering 31 Spline Axles
Strange Engineering C-Clip Eliminators
03' SVT Cobra Traction Lock
3:55:1 Gears
Machine Work:
Flywheel Resurfaced
Hot Tank Block and Heads
Hone Cylinders
Check Align. Bore
Install Cam Bearings
Install Core Plugs
302 Three Angle Valve Job
Surface 302
Micro Polish Crank
Rotating Assembly Balanced
Misc:
Block, heads, lower intake, oil pan, and water pump painted Ford Dark Blue
How come it has 2g pistons? Looks awesome for a 1g imo! Lot better than my buddies!
ColdAudio said:
awesome car man looks very clean and great deal for the price, but wtf is up with the glove box? ROFL
Its starting to peel up. No big deal Ill take care of it :)
I wondered the same I asked the seller and he said the guy before him put them in. I really have no idea thats all he could tell me was the previous owner put in new pistons, must have fubarred one or was having some problems with the rings im not sure.
Bryan90TSiAWD said:
nice find. thats a clean body!
thanks bud theres rust about the size of a quarter on the inside of of the rear fender well on each side but other than that its cleannnn. I work for a dealership so I can get a nice discount in our body shop so I will be taking care of that this spring/summer if my wallet permits. been spending too much on tools
Looks good. It looks like your driver headlight is yellowed. Take some Flitz to it and it will look good as new. Nice find! :D
Believe it or not I use Mothers polish and works better :)
kottyking said:
Looks good but one thing. Put a cover over that timing belt.
I know I know, I am on some local forums and I got a bunch of shit for it. Im getting there I need to get another pay check. First things im doing when I get paid...
Oil Change/Filter
Build a boost leak detector
Fix the exterior door handle on drivers side
Put in a new lock cylinder on the hatch
new hatch supports
new upper timing belt cover
and head to the junk yard and see if I can find any small things I might want :)
Yep, a junk yard is great for little things like timing cover. You'll find a lot of 1g's have bad shocks on the hatch so 1g's at the junkyard are probably the same. But yes junkyards are good times cause you never know what you'll find. Happy Hunting:thumb:
Yeah well the timing cover im ordering new because I need it asap the rest if I cant find it at the junk yard I will order it new :)
Very clean car, hopefully it runs as good as it looks:thumb: You go show your Mustang friends who's boss with that GSX:tease:
BTW Are those Chrome windshield wipers, cause if they are you need to throw them away as soon as possible ROFL
luvmygst said:
You need to be carefull I can tell youi from expierence that a dsm can cause mustang neglect!. I bought my gst to drive while I turbo'd my stang and I ended up modding the eclipse and the stang has been pushed to the back burner. But at least it's nice to have 2 cars to drive.:rocks:
well i added my mustang to the post for yours or anyone elses pleasure
wow i should be able to sell mine then easily! LOL mine looks just like that with alot less miles and alot more mods! and i'm asking 4k anyone? LOL
First off, welcome to our site.
I am glad you appreciate the site and its members efforts to help others. Contribute as much as you can and help make the wheel go round.
That is a clean DSM you found there. Is it a 6/4 combo? Take care of her!
Your mustang project looks to be comming along as well. Keep us posted. Our Gen5 454 block (for our 65 Corvette) will be back from the machine shop in a few days and I am anxious to start assembly. Multiple projects rule.
welcome. i like the GT a lot. i never really got into them until my cousin bought his 96 GT. i heard the 96 mustang GT 4.6 engines only put out around 215hp instead of the rated 260, is that true?
