Norcalgsx707
- 564
- 0
- Jun 28, 2012
lake county,
California
heres my first dsmlink data log if anyone wants to shed light on whats going on here that would be cool.
Is everything stock? If not, update the mod list in your profile.
And please read these threads:
http://www.dsmtuners.com/forums/ecm...efore-you-ask-ecmlink-dsmlink-log-advice.html
http://www.dsmtuners.com/forums/ecmlink-tuning-help/444831-list-values-log.html
Are your fuel injectors stock? (450cc) or something different?
Are you setup for Speed Density?
Ok I am not savvy with Speed Density. But you should watch the demos on ECMLINK to get your idle set good. Also you should make sure you have 0 boost leaks.
He says they're stock...Are your fuel injectors stock? (450cc) or something different?
Norcalgsx707 said:how do i fix this running rich thing?
no he's definitely not on sd...
zero out your mafcomp sliders for now and post another log...
What is your fuel pressure set at?
So just reset the mafcomp? Oh I updated my profile too you can see what i have.
Its telling me incompatible data because some data is incompatible with this ecu config
Yeah, that was an older version. I just updated the link to the newest one. Try again.
By the way, your combinedft is much better at 8%. Now warm the car up and it should lower
Should i be good to go tommorow can i drive it like that, i dont want to create any problems
To me the blue fuel line looks crazy compared to the one that dsmlink shows on there sight
I applied your settings one by one and logged it ill post it up right now
I was playing with the tps earlier what do i need to look for I was wathicng it jump around from 7.1 up to 9.9 is that normal, and I had the throttle pos at 0 percent
btw i just need to log those when going driving right? yeah i know I got alot of questions but i got to start somewhere last thing i want is to replace my engine because i screwed up on something small u know
to dial everything inYes, it's a must once you start tuning.
You need to start with idle, unless you have that all dialed in. Post up an idle log.
