My door panel is broken at the fingerpull
EclipseGST-95
531
Aug 5, 2003
Newark, Delaware
When i pull on my door it feels like the pannel is gonna pop off. I took the little screw cap off where the hole is where you pull the door shut....and the plastic is cracked so the screw is down and the plastic isn't held down. Wwhat do I need do to to fix that so it gets pulled shut like my passenger door still does?
I have the same problem. You cant really do anythign about it. I took my dor panel off and tried to do diff things like put a piece of plastic and jb weld plastic it, i tried glassing over the hole to have something for the screw to go into. But none of it worked. Its not really gonna tear apart. You have like 8 or 9 other screws holding your door on...not literally but ya know what i mean
im wondering if i can get a new piece, not the whole frame just the piece that the screw gets held down in...i wish someone has had this problem and has done something about it would post something...:cry:
There is a replacement piece that you can buy for your door panel. I've ordered one before from mitsubishi for about 30 dollars for the whole plastic piece including vent and power window switch plate etc. Anyways, when I get home and am able to check my caps program I'll give you the part number.
