My Car Won't Stop Reving To The Max
Ok now I suspect something seriously wrong, I installed my new map sensor and tps sensor now it gives me different codes here they are
tps sensor a circuit high input
engine coolant temp sensor circuit high input
iat sensor 1 circuit high input
UPDATE: Well after working on my car all night I found one of the problems, I pulled my head and that mechanic that I took it to that said he couldn't figure out what was wrong with it after taking of the manifold, guess what he did, the gasket on the intake manifold was all jacked up. He didn't even have it lined up I mean its hard to explain, he literally didn't line it up he just mis placed the gasket and poked holes all through it. I am hoping that is where my huge leak was coming from and why my car was reving up like that I already have another one and I am fixing to go call him and tell him what he did. Not to mention part of my valve cover gasket was melted somehow and was leaking oil out. I just spend over 100 dollars on sensors that i probably didn't need to. i am going to replace the head gasket while I am at it what brand do you guys reccomend? I will be using my arp head bolts to since I finally get a chance and would there be any point in my putting on my crower springs and retainers? I originally bought them for my stage 3 cams but I never got them because the guy kept my money.
Update- My car runs perfect now except all it needs is a new valve cover gassket and new plugs. It was the I.M gasket that was causing the rev and there was a vacuum hose that was disconnected that was from the black box underneath the I.M.
