My car wont pass 4500rpm
fantompr
40
Dec 11, 2007
san juan, Puerto Rico
hi
The new problem of my car is wont pass of 4500rpm like limiting (runing)
stop in neutral shift, limit in 4000rpm and i saw the car pull a lot of boost
like the antilag wich i have disable.
i checked the park plug and installed new ngk bpr6es gaped to 24 and still
the problem
Any help is welcome
Thanks
hi
the problem
Any help is welcome
Thanks
Limiting... is it:
Studdering?
Bucking?
Not accelerating?
Fuel cut feeling?
I'm having a slight bucking problem. I wanna blame it on the fact that i have a few too many mods & no tune :hmm:
ecu is my bet. mine did the same thing at 3000rpm. does it spit a lot of black smoke out when its acting like its antilagging? my ecu was junk and caused a super rich condition that would literally make it 2step. i could build 15psi of boost when it did it haha.
Does that only happen when you aren't driving?
Maybe you have your 2 step enabled?
all the plugs are well conected (power transistor maf)
and the problem is when im driving
when im stop (neutro) the car start the problem 500rpm early.
I try to pass the 4500 and the unique way is running in vacuum and anyway start slowly the problem
like stoping and explosion exhaust (sound)
My car is tuned by a pro for 18psi and i drop the boost to 12psi thinking of if i droop the boost i can
fixed the problem but no still that.
Sorry for my bad inglish i dont speak inglish and thanks.
Someting like that but running and stop
My mechanic think can be the ecu.
But im checking other alternative
Check to make sure your clutch switches are connected properly and the speedometer works.
yes all is good the car was working good until start the problem
like 2 month. i miss touch the redline LOL
^^^let my try to do that soon
because i dont have laptop but let me see what i can do to post a log
