My build
1991_talon
156
Sep 25, 2010
Connersville, Indiana
I want to put a t4 turbo with a new intake and a new magnus intake manifold I will have a 3 bolt LSD DIFF stock awd chasis can I hold this much hp on stock suspension? My motor is bored .030 over and has crower cams, truck crank, eagle rods and wiesco pistons. How much power do you think I can make from this application.Y
t4 turbo doesn't really give us much info about the turbo, you will need to be more specific.
Imo your suspension doesn't have much todo with your HP goals.
Try this thread. http://www.dsmtuners.com/forums/hangout/382800-official-bench-racing-thread-how-fast-my-car-how-much-hp-can-i-expect.html try some more reasearch make sure profile update with all your performance parts. Horsepower numbers can never be said, all depends on your tune and how good your car is running. Best guesses any person can learn to make is what turbo there running. Lets say u run a 16g so look at 300-350whp. If you run gt35r look in the 500whp range, and gt40 600-1000whp range. So hope this gives you an idea. Everything else like say u wanna add cams that be like adding 20hp. All these depend on the tune, boost, and health of your car. Good luck.
I have everything on that list except the two aftermarket intakes and the turbo which is a 69mm wheel, as of now i current have a 60mm wheel on my turbo.
You updated everything but what injectors you have. I would upgrade 2.5 link to 3.0 even lite it won't be alot of money. Are you staying on pump gas get atleast 1000cc injectors. If your running pump gas to and wanting to know how much power you will make it won't be fully capable unless you run race gas or e85. Hope that helps go dyno let us know how you did.
This is a build in process swapping from fwd. Im running1280 injectors Could I run a Y link piping to my intake if I can find a way to twin turbo this beast Ill use my 60 and 68 trim. Can it be done?
The best way to run twins is compound charging like Clipto mentioned. But honestly, that's one of those things where if your asking how to do it, you shouldn't do it.
Okay what if I run two waste gates linked together at one side the then the other side linked to both turbos. Which I guess I could then hook them in as a single line right?
