My 92' Talon TSI AWD project.....
lilzig
Feb 7, 2008
Youngstown, Ohio
I have no pictures yet...
But i did take the head off and sent it to the machine shop. I'm getting stainless steel valves because all of my other valves were bent when i bought the car.
I am also getting all new valve guides, the head is getting port and polished with a 3-angle valves job. I am keeping the stock springs and retainers for now...
I just ordered ARP head bolts, a head gasket set, water pump belt, and also am looking to purchase a radiator. The pistons were knicked but not the edge of the piston head..
I am posting pictuers eithers tomorrow or saturday...
Is there anything i am missing to complete my little build?:hmm:
why are u porting and polishing? will the flow test it before and after? also 3 angle valve job is considered a normal valve job. Water pump belt? u mean timing belt? make sure u get the rest of the components and decide if u want to do the BS delete or not. What head gasket did u get?
The lifter on the left is a 3G lifter the one on the right is OEM. 3G lifters doesn't refer to lifters out of a 3G eclipse, rather the 3rd generation design of the lifter. As you can see the oil port is much bigger than stock so it doesn't tick so bad.
Good luck, But this thread should be in the hangout section were it says project/build thread.
