my 420a turbo eclipse
Agent0023
Aug 25, 2009
Clewiston, Florida
so whats up people. iv had my eclipse since 99-00 and its coming together. i had a lot of problems but it seems as if all thats behind me. the car is running good after a tune up,because it sat for two years :mad:iv yet to dyno it and see what kind of power its making.But as soon as its out of my friend's shop ill get it dynoed and post the results.im currently running a Hahn race craft super 20G turbo with full 3" exhaust from turbo back.I need any input that i can get on cooling because im having a problem with that.
What size intercooler you running? I did a fluidyne conversion on my coolant and that really helped a lot. I would do as the other guy said though, check water pump, air pockets, that kinda stuff. Your stock coolant system should be able to keep it where it is supposed to be. Fluidyne is a nice upgrade, but not needed by anymeans.
***edit***
What sort of engine management are you running?
Update your profile, I understand TOO MANY TO LIST, but suck it up and do it. How are we supposed to give you honest opinions if you won't share the appropriate info?
Was going to mention fans... Are you sure both of your fans are working correctly? I know its a stupid question, but it might be that simple.....
