1G My 1g not running correctly....
Dsm Gst
Mar 8, 2010
Pekin, Illinois
its was running fine before i switched the side mount for a front mount and now it doesn't want to go, like if i get on it it like shuts down. It's not fuel cut but it didn't do it till i switched intercoolers.
All couplers are tightened and everything else is tight, only thing is that i have a 1g bov on and i dont have it recirculating could this be the problem?
do i have boost leak? before i switched intercoolers i had a type rs bov on but i like the sound of the crushed 1g better....idk why its acting up?
You've already answered it. You don't have the BOV recirculated so you have issues. Plumb it back into the intake and check for boost leaks or a hole in your intercooler/bad weld somewhere. The only way to run your BOV vented into the atmosphere is to get either a stand alone ecu, MAFT with a GM MAF or speed density system.
i cant find another rec. tube online and nowhere in my town has anything similar :confused:
any1 have any others ideas on what i should do?
The least attractive but still effective thing would be to find either a pre bent radiator hose of the correct inside diameter that you can cut to fit. Another option is to (so I've heard but never seen myself) is to get some pvc piping and bends to fabricate a hardline connection between the two. Those would be the two options I'd suggest other than finding a factory tube to replace it with.
