mhuffman
- 292
- 4
- Nov 3, 2006
Bowie,
Maryland
I have 91 GST with 3" DP, 2.5" cat, 2.5" muffler, no free mods, stock MAS. I have new 0.028" NGK's and accel wires. The car runs really well and gets 25+ mpg. It also runs smoothly to 6000rpm+ when not full boost.
However, at around 5000+ rpm's and only at full boost i am getting complete fuel cut (AKA brick wall). I idle smoothly at 19 inHg and the turbo spools very well (14b). My dad followed me and under full boost i do NOT blow out any black smoke (AKA not running rich). I do not feel boost spike before i get fuel cut, just a smooth pull and them WHAM. Otherwise, the car runs very strong. I have no reason to think i have any boost leaks or a malfunctioning wastegate.
Thanks.... DSM's are a PITA!! But they're so fun!
UPDATE: I did a pressure test... i'm getting a major leak from the turbo. I suspect it's the compressor seal. I can feel and hear major air leaking from the compressor, the system only holds air for 5 seconds if i go to 10psi, the leak is that big. I guess i pinpointed the cause of my fuel cut.
I called a local dealer and they said they have 4 in stock for $5 each, so ill put one on and post if it fixed the problem or not. Thanks again with the help everyone.
UPDATE 2: I fixed it! Hey everyone, i replaced the seal and no fuel cut, it pulls much smoother and driveability feels better. The old seal was flat, hard, and cracking and disintegrated upon taking it out. It took a few hours but it was well worth it. If anyone's interested in a How-To i could make one. I replaced the seal with the ex. manifold and turbo housing still on the car, i just removed the center section and compressor cover. Seals are only $5 at any local Mitsubishi dealer. It's just the labor and the special tools.
