My 14B/16G custom install Kit - Is this ok ?
CONSIGLIERI
181
Oct 6, 2010
Columbia, South Carolina
Hello friends !
I have finally decided my 14B "install kit" and I would appreciate if you could give me feedback and ideas of something that I need to add or change. I will use it in a factory side mount intercooler.
* J-Pipes and Oil Feed Line -> GODSPEED INSTALL KIT
By the picture and some reviews, it seems pretty decent for the price. The Oil Feed lines look very good and looks like even have the banjo bolts and fittings.
GSP DSM TURBO INTERCOOLER J PIPE 4G63 D32A D33A (FOR 16G AND 20G) PERFORMANCE | eBay
* OEM Exhaust Manifold Gasket (4 Ply) : Mitsubishi Eclipse 90-99 - https://www.extremepsi.com/store/product.php?productid=19172
* OEM J Pipe Gasket : Mitsubishi Eclipse 90-94 - https://www.extremepsi.com/store/product.php?productid=17640
* OEM O2 Housing Gasket : Mitsubishi Eclipse 90-99 - https://www.extremepsi.com/store/product.php?productid=17639
* OEM Oil Return Line Gasket : Mitsubishi Eclipse 90-99 - https://www.extremepsi.com/store/product.php?productid=17641
* OEM DSM Turbine Housing Inlet Gasket (6CM) - Forced Performance Turbochargers: Mitsubishi DSM Turbine Housing Inlet Gasket
* Exaust Manifold Studs - I will reuse the ones I have in the car. I even considered buying a whole set, but it don't think I'll need those.
* Water Lines and Oil Return Line - I will reuse them also... I searched for a new 1G return line but it was U$ 75 ???? Too expensive... Is there other less expensive option ?
* 2x 2'' -> 2.25" diameter Reducer Coupler - Tube Reducer
* 2x 2.25" T-bolt Clamps - T Bolt
* 2x 2'' T-bolt Clamps - T Bolt Clamp
Thank you for your help guys !!!
For the Oil return, All I did was dremel one of the bolt holes wider to accomodae. I've had it for 4 years with no trouble on my 16g.
  • Wanted 6 bolt NT water pipe
    • chrisman287
