Is this the right 14b Install kit?
Dready
68
Apr 30, 2008
NMB, South Carolina
Does that look like all that is needed to install my 14b on to my 2g?
Any thing else i might need?
Thanks
Although It's a good idea to tap the J-pipe for a mbc source, not everyone does it. Also have to agree the kit doesn't look like it's that great. But it will work. I have upgraded from the t-25 to the 16g so i know where your at. Be ready to have some copper lines and some rubber houses for the coolant/oil lines if your using them instead of new lines. It's a weekend job so have fun!
i had trouble with my lower intercooler tube when i switched over to the 16g, my j-pipe dumped over to the driverside of my cross-member, i had to get a 90 degree coupler off of my 1g parts car and use a small piece of pipe that i had welded a bead on so the thing didnt blow apart on me.
I wouldn't trust that oil line at all, ive heard horror stories of people having these cheap oil lines failing and causing engine fires along with blowing up turbos. Other than that everything else seems to be fine.
  • Wanted 6 bolt NT water pipe
    • chrisman287
