Motor swap idle issue.
g4ebguy90
2,001
3
Mar 9, 2011
Rockford, Illinois
Hi guys, I did look through some threads by other people but it's a little different.
I just got done swapping heads from a 1990 6 bolt, to a 91 6 bolt. I got the car to start after a couple cranks.
Now it just sits there, and goes vroom pa vroom pa vroom pa.
Like 1500 to 1000 then it repeats. I noticed if I turned the cam sensor, it either made it faster or slower but didn't stop it, I assume this is due to ignition timing.
So, I unplugged the IAC, and it didn't do a darn thing... But I thought that was normal?
and ideas
Also there is a sensor on the thermostat housing that I broke :(. I don't know what it is though, I assume cooling fan switch but idk, it had a dark peice of rubber covering the whole thing.
After reading that, I tested the coils on the ISC they are good, and again If i unplug it idle does not change.
You may have broken your coolant temperature sensor, which tells the ecu when to exit out of warm up mode. As far as the idle sure you can start by trying to pin point vacuum leaks by spraying starting fluid on your vacuum hoses. You could also clean your throttle body, it might help out a bit.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
