motor swap: 1990 laser 1.8 to a 1993 talon. will ecu's work
lilpastrana
53
Oct 30, 2005
centuria, Wisconsin
picked up a 1993 talon 1.8 bad motor want to put my 1.8 laser engine in it want to know if the wires and the ecu' are interchangeable. reply asas please!!
If the motor that came out was a 1.8 liter and the motor you are going to put in is a 1.8 liter, it should drop right in. No need to swap harnesses/ecus. Everything should plug right back in, if parts/plugs dont match up swap them off your original motor to make things right.
