motor mounts
you will need the actuall mounts that bolt to the 4g63 and the upper drivers side bar that mounts to the 4g63 by the cam gears. the locasions in the chassis are not changes. from what i hear it is a bolt in if you find the right parts.
i think the ecu is different too.
ECU, Wiring Harness, Drivers side motor mount are different. Wouldnt be a bad idea to get, at least, a 2.0 N/T cluster at a minimum. Also, are you installing a turbo transmission and axles?
I highly doubt the tranny for the N/A 98hp 1.8l will handle the power of the turbo motor for very long. Also, it doesn't matter what the engine has, it's not going to work without the wiring harness ad ECU.
Motor mounts and brackets are not the same between 1.8, 20 n/a and 2.0 Turbo even though they are all fwd cars. The differences are not huge but they would prevent your engine and transmission to sit right.
