Motor Mounts Time for DD/track Project
murcielago
169
Sep 12, 2010
Central Jersey, New Jersey
Hello Tuners.
I have come down to the time of putting my Motor Mounts.
I need some suggestions on what i can do or if my idea is pretty good for what i want..
I have not updated my Mods on the Mods list in my profile because i have not yet driven the vehicle to be sure how it runs or if i have to change a couple of thigns around, bt so far this is what i have done and what will go in within now to a month:
Looing for 300hp, maybe 250-275whp...
Big T28-Ported..With boost set at 17psi(adjustable regulator)if more if needed to where i can get the max out the turbo without hurting it like around 19-21psi then will run it at that..
ETS Street 7" FMIC..
Walbro 255 re-wired full pump..
Fuel Lab Mini AFPR..
Not yet done: 560cc(EVO-9 Injectors)or maybe PTE 580CC..Will run stock Injectors at 17psi until next summer, if i see fuel issues then will upgrade asap..
Not Yet done: Ceddy Mod for Fuel adjustment and Launch Control..
Full Suspension(basics);, H&R Spring with KYB Adjustable's front and rear, Rear Swaybar RM, (front is stock), Not done yet:(front and rear strut bars)..
NGK Spark-Plugs & Wires..
Force Performance Exhaust Manifold..
2 gauges: AEM Wideband, Autometer Boost..
K&N Filter Kit(STM)
Force Performance Intake Pipe
2 Catch cans-PCV system side, and Turbo Intake side
Not done Yet: Tune for its best power without hurting engine-turbo
Now back to topic..
Looking to buy the Avid 3-Piece Street Kit from STM, but i also want a new Front mount which doesn't come in the kit nor by it self, i would like to know if i can put a Track-style Front mount piece or will that just be a waste and damage the other mounts or the car feel weird? i don't really want the Track kit for the reason that they are stiffer and more vibrations, although i've never driven in a car which is track kit equiped, any suggestions on that? but i was also thinking on buying an oem front mount and putting Poly insert on just that one since the other 3 would already upgraded, Since i can get the poly insert from STM for the front mount by itself, im thinking this is my best route unless you guys think that 4-piece track kit is the way to go? remember this is a DD/and track times during next summer..
Thank You for reading and please let me know what You guys think...:thumb:
Murcielago
Francisco
why do you want motor mounts? spend your money else were. your stock mounts should not have a problem with 300hp.
2 of them are worn, so might aswell replace them with solid or better then OEM for a car on its way to more WHP.. :D
Good mount do wonders for even a stock car when it comes to shifting and halting wheel hop
have you seen these for the front and rear mounts
2G polyurethane roll stops/motor mounts - DSM Classifieds
those paired with the regular Prothane or ES driver and passanger side mount make for a great setup
nice wow i just sent you a PM.. please get back to me.. Thank You
I got the avid 4 piece and I love it, I got the street/strip ones not stiffest but not the softest either
A Big T28 has greater potential than a small 16g. Besides, he doesn't require hundreds of dollars of different turbo to reach his goals.
AND the OP's question was about motor mounts.
This right here is true!.
If for some reason i max out my T28, meaning MAX out to where i see i cant get up my 300hp-or close to 275whp, then i will go with an evo3 16G but after searching a couple of threads, this Big t28 can do it with the right Mods and plus i like the quicker spooling since dd i can't even get up to 100hp around city,s o might aswell get something quick instead of high MPH around here.. O an dmy goal is pretty much Road Races.. with this T28 i think i can do alot but we'll see what happens.
Thanks Anyways:thumb:
Wait you got the Street.strip one as a 4-Piece set? where from because i've been looking for them i can only find 3-piece set for Street/Strip, and only 4-piece set in full track...
Thanks:thumb:
PM me.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
