more Tranny questions.
BlackMount
803
Jan 20, 2010
Monroe, Wisconsin
so my 30$ tranny finally shit the brick. No matter what I do it won't go into gear,
Started slowly having more and more trouble going into gear, now it refuses to go into at all.
If I start rolling tho, I can sync the revs of tranny\transmission. and get it to pop into gear with no grinding or anything.
so I have a few opportunities
there are a few F5m22 Transmissions at the junkyard right now for cheap, I could buy one, and throw it on, but I was told the turbo 7 bolt flywheel won't fit in the f5m22 Housing which is from 1.8L's and Non turbo 2.0L's. So I can either A: swap out the bell housings off my F5m33 tranny onto a F5m22 Tranny (seen again and again the only difference is the final drive) can any one confirm if that will work? or B: Get a non turbo 7 bolt flywheel but god knows when one of those will turn up LOL, and I'm not about to buy a new or aftermarket one, I cannot afford.
or pay a lot extra money and get another f5m33 tranny.\
I would prefer Option 1A if it will work.
My only concern with option 1 are the axles. I know there are early and late FWD axles, do they change between nonturbos, and turbos as well?
no all the axles are the same except for the AWD's
I am using the stock axles from my 94 FWD N\T Auto Talon with a 90 FWD Turbo Tranny. They work fine.
can anyone confirm the bell housing idea?
he was no help so the question is still up. are the bell housings interchangeable.
I honestly don't know that anyone has ever done this. And from the handling both side by side I'm about 85% positive that they are not interchangeable. I've been wrong before though however.
Also there are different axles. The 90-92 turbo's and 90-94 nt's share the same axles, the 92.5 - 94 fwd turbo's had larger axles.
Sorry I have no updated, but when I pulled the tranny out a few days ago on the DSM I was able to tare it apart and confirmed this not work.
the auto tranny it might however, but that's a whole nother topic.
