2G Moog K80564 sway bar link
PlanZero
1,516
267
Aug 13, 2013
Easton, Pennsylvania
I noticed I needed some new front sway bar links when I swapped my steering rack, and depending where you look this moog part number shows two different style links. One has a beefier rod and the other has a stock appearance. Has anyone bought these recently and if so which ones did you receive?
Yes I am trying to make sure I get the thicker ones, but when I search I find two different images for the Moog part.
And Dsmkauai, I saw those MAS fronts on rock auto (I have MAS upper ball joints that are holding up well), but I don't understand how that extra nut works. Is it supposes to go behind the sway bar as a jamb nut? I prefer the links that have something behind to clamp on to to prevent the stud from spinning.
And what is the big difference in quality between Moog and Quicksteer sway bar links, the "entry level" in federal mogul's chassis parts.
Rock shipped me two mismatched parts under this same number, one being the thin style and the thicker. Both were non-servicable.
Amazon sent a matched pair of heavy style links under this part number and both had Zerks installed where the ball end met the rod. This means MOOG has at least three types, all under the same part number.
I sent both the Rock-sourced MOOGs back. Apparently they source stuff from multiple sources and you get what you get.
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
