money to burn
blitz43
335
Jun 15, 2004
new port richey, Florida
hey guys i got 750 to burn next month and i want to invest it in my car
this is what i have right now
hallman mbc
full 3"turbo back
walbro 190
1g bov
ngk 7s
what do you recommend i should get next??? turbo?
fuel stuff anything is all good thanks
b16g - 400
afc- 225
550's - 175
50 bucks over your goal but thats what I would do, you have decent supporting mods. might need a datalogger as well. go big or go home ;) port your manifold, o2 housing and that will put some nice life in your car compared to the t-too small
laxdudeee said:
b16g - 400
afc- 225
550's - 175
Sounds good but I think those prices are abit cheep, unless your talkin about used? But before you add those I would say get some kind of intake and upgrade your ic pipes. If you did go with the above listed items you should also get a logger, & a fpr would also be a good idea, which would put you a few hundred over your budget. Being your fwd urthane motor mounts are also nice & will help with traction/wheel hop. Since you have a MBC I'm guessing you have a boost gauge already?
Intake pipe should be the first thing, along with a filter. Intercooler pipes and S-AFC would about wrap up your budget for next month. Next time you have cash, start thinking about a turbo and all the matching pieces to go with it, like the exhaust manifold. Invest in some gauges to monitor your vitals if you haven't already, and an upgraded clutch to be safe.
i'm guessing that you're starting off with no mods done so far after reading your vehicle profile:
free mods
plugs/wires
shifter base bushings
underhood shifter bushings
mbc
fuel pump with a rewire
ported 2g 02 housing
ported 2g exhaust mainifold
3 inch turbo back/high clow cat/muffler
boost gauge/pod
as far as the price goes on the parts it really depends on where you buy from and if the parts are new/used
