Mods for 720 injectors
I'm assuming you've got an maft to handle the gm maf right? If so, then you can just set the base injector setting for 720's but you won't ever get a solid tune out of it.
650's are about the highest you wanna go on piggyback tuning before you need something like dsmlink or the aem system. So techinically no, it's not too much fuel IF you had a way to accurately control them. But you're all set on your other supporting mods to handle them, technically, you'd be fine to put them in a stock motor as long as you had a way to control the flow.
But no, if i were you i wouldn't run them with just maft. You need something more powerful.
