Model Info Help
92ttawdstealth
Nov 1, 2006
., Minnesota
Ok I couldnt really figure out a good title for this thread but I have a 92 GSX that I'm trying to find out if its a 6-bolt or a 7-bolt and before anything is said about searching I have done the vfaq identify method with the oil pan and found that mine is so dented up that its hard to tell so I was wondering if there is a way to tell by using the Manufacturing Date which is Jul 91?
Are you sure it's a 92? That is about the same manufacture date as my 91.
I expect with that date, anyway, it should be a 6 bolt. It was early to mid 92 they switched over. (May maybe...?)
