MMcd parameters mean?
2fast4
95
Dec 6, 2005
NorCal, California
Been playing around with MMcd but some acronyms is ambiguous. Can someone explain, or point to weblink that explains stuff like FLG0 FLG1, etc? Thanks.
flg0 flg1 stand for flag0 flag1, not sure but i thing they are warning flags that you can set to let you know limits, when you set them like rev limiter.
Go into the parm setup of MMCD, (where you can set the custom settings) and hit the info Icon in the top right( the "i"). it will list the names and what they are. Although it doesn't tell you what they do.
It's not the same but http://www.hywell.org/plhelp
will tell you what they mean.
Also some in the MMCD are not on the above site.
MMCD:
Standart sensors......
FLGO:
A: A/c relay
F: fuel pump relay
B:boost solenoid
FLG2:
T:top dead center
S: P/S load switch
A:AC Load Switch
N:Neutral
I: idle switch
TIMA: timing advance
Cool: coolant temperature
FTRL: Fuel trim low
FTRM: fuel trim medium
FTRH:fuel trim high
FTO2: O2 feedback trim
EGRT: EGR temperature
O2-F: O2 sensor front
O2-R: O2 sensor rear
BATT: battery
Baro:Barometer
ISC:Idle speed control
TPS: Throttle position sensor
MAFS:Air flow Hz
ACLE:Accel enrichment
RPM: RPM
Knck: Knock sensor
INJP: injector pulse
INJD: Injector duty
AIRV:air volume
AIRT:air temperature
those are some I have on my MMCD.
