MMcd questions
flying_eagle
118
23
Feb 13, 2008
Pampa, Texas
i have mmcd v. 1.8 and i was wondering which of the readouts accually work. I know the basics like RPM work, basically most of the one on the firtst page work, but which ones are accurate like air temp. Also of the ones that work where is the sensors for them. here is a list of the ones I'm not sure about.
Cool fto2 map plen
airT mafs oilp pump
baro acle egt
ics oilt
vspd fuel
Also i know that flgo is the a/c relay fuel pump relay and boost solenoid
and the flg2 its the tdc ps switch ac switch and neutral and idle swith
Like i metioned above of the ones that work where are the sensors
Do you happen to have a MAF-T? If so you might notice that your air temperature doesn't change very much at all, and it is because the MAF-T outputs the temperature as a constant 26.66C/80F...MMCD is as accurate as the sensors it reads. Your air temperature, baro and MAF are all read in the MAS (which is by your air filter if you are stock, or along your IC piping somewhere if using a GM MAF and MAF-T).
