Missing link questions
DSM Racer
Aug 28, 2008
Wichita, Kansas
Hey guys couple questions regarding missing link. Is there anyway to run it on a stock intake manifold or do I need to use the OBX?
Also I've have a hahn port fueler, can I still use missing link?
Thanks
Use stock, its way better then OBX.. the Missing link will work just fine with stock. It goes between the stock Map sensor and the IM. id also suggest getting a FCD. the Missing link is more for protecting the Map sensor, and the FCD is more for performing the actual "map voltage clamping" that youll need to avoid fuel cut.
I always suggest to run both for the reasons above.
Just an fyi guys. Don't order your missing link from Direct Tuning. I waited a month, emailed them twice and didn't get a single response or any information on the order. I ended up getting my money back from PayPal.
im looking into the FCD for my ride, but i currently have the missing link, how would you plan to use both at the same time on the IM?
The missing link physically fits between the MAP sensor and IM, the FCD just connects to the MAP sensor's wires. There's no physical conflict between the two devices.
