Minor steering problem
Madcow1041
48
Sep 10, 2005
Stamford, Connecticut
I finally got my new used car. There are a few minor issues (besides my speedo) that need to be fixed. One of the more irritating problem is, my steering is a little less responsive than it should be, and it squeaks when turning the wheel.
It may be a minor problem, but it's a little irritating. >_<
check your powersteering fluid level, and the tubes, belts, and connectors, something may be loose. get an alignment. check your rims, if one is bent your steering would suck badly
Check the tierod ends and see if they are loose in the control arms. I mean a little slop without moving the control arms is bad, they should be tight with no movement.
